1 members (Southerntruck), 162 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#899874 11/28/2012 11:46 AM
My '51 3100 3OTT is all of the sudden loud in first. It's not chattering or anything, its just really loud. Only in first gear. The mount (an old chunk of truck tire tread) split and fell out. I replaced it with the correct two part mount and it developed this issue.
Any ideas?
ODSS Lawman
ODSS Lawman
Were the two (tire and proper mount) the same in all dimensions?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
No, close but not perfect, and I was just thinking about that but wouldn't that cause issues in all gears?
Have you checked the oil level?
My Blog
I am embarrassed to say, not yet. Tho, I only drove it home from my friend's place after working on it and it has sat in my driveway since.
I know what to put my money on.
My Blog
Haha. Yeah, yeah. I'll do it on friday. smile Still tho, why do you think it would it be fine before the mount slipped and not before and after the replacement was installed.
I think since the mount fell out, This put more pressure on the shift rod for first gear, kinda amplifing the gear noise following up your column. Like putting a wooden dowel from your ear to valve cover. Put the proper mount in and I bet it disappears.
alltruck72, I have the proper mount in now. The one that fell out was a chunk of old worn tire tread. I'm wondering if because the clutch was put in with the old, incorrect mount maybe something is out of alignment and needs to be adjusted.
You're allowed to say "told ya so", Dave. blush
There the rear dif was definitely old juice and there was almost nothing in the trans. Drained em both and after refilling, it all sounds better than ever now!
Very Good!
Keep an eye on the oil level, these old Chevy's like to loose there trans oil.
My Blog
Good to know. Thanks for the heads up! Judging from the build up of grime, it looks like mine might be leaking right where the torque tube meets it.
If you decide to fix the U' joint bell leak make sure you follow the instructions in this link. Right side of page, half way down.
My Blog
I got a good deal on a '49 Pontiac with a "bad trans" one time. It howled in gear terribly. I filled the empty three speed with oil, and no more noise!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Was the rearend over full? If that is the case the seal behind the driveshaft bushing is allowing the transmission fluid to run back to the rearend.
1951 1 Ton Completed
I used to have to regularly drain the excess from the rear end of my '51 and dump it back in the tranny before I rebuild the TT.
Kurt
