1 members (Hotrod Lincoln), 55 guests, and 3 robots.
Topics128,090
Posts1,056,376
Members48,442
#890574 10/19/2012 3:55 PM
I have read many great posts on installing a t-5 in the 60-66 c10's but I was wondering if anyone has installed one in a k10. My truck has the 4 speed with granny gear and I would like to go to a 5 speed. Any info or sugestions would be great.
Thanks Alstepside
Alstepside #898721 11/23/2012 12:36 PM
Bump. Your '66 should have a divorced transfer case. Have you thought of installing an overdrive unit instead of swapping the transmission? I believe some of the older Volvos have an electronically controlled overdrive unit that you might be able to adapt for use in 2WD.
Alstepside #899634 11/27/2012 12:44 PM
Or perhaps you could get the entire transmission/transfer case from a 4wd S10. Admittedly it's a little weaker than your current setup, but you did say K10 so if you aren't planning on any serious pulling/towing (which you probably aren't with a T5 anyway) it might work out for you.
I have a 65 k20 and have been thinking of a swap to my thought is a nv4500 from a 2wd then all i should have to do is shorten the intermediate driveline. Any thoughts?
Alstepside #900817 12/02/2012 11:09 PM
I like the NV4500 swap, but you will still need an adapter or bell housing of some kind. There is NO NV4500 that will bolt to the Chevy bell housing. I thought there was, too, but they are vapor ware and do not exist!
Les
