6 members (Otto Skorzeny, WICruiser, HandyAndy, Dennys28, Ridgeback, Peggy M), 112 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#898049 11/20/2012 4:22 PM
I'm finishing up the painting on my 39 Chevy 1/2 ton and need to know about the stripe that goes all the way around the cab? The truck is boatswain blue and the stripe is red. However, where does it start and is it as wide as the, what I think is called the belt molding that goes all the way around the cab?
Thanks for your help!
tom
Tom
back yard wrench turner
Does this help?
http://www.classicautomotiverestoration.com/1946_Chevrolet_1500_pickup.html
I did a google image search for 1939 chevy truck.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Are there any restored ones in our gallery?
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
nanneyman #898260 11/21/2012 10:12 AM
I have a GM drawing with location and size for a '37.
Joe
nanneyman #898288 11/21/2012 11:30 AM
Also, is the cab stripe a painted stripe or a taped stripe?
Thanks to all who responded!
tom
Tom
nanneyman #898301 11/21/2012 12:53 PM
Tom,
In that era, everything would have been painted.
Wayne
1989 Silverado
on my 39 3/4 ton the stripe was about an eighth of an inch wide right down the middle of the beltline, plus all the indents of the hood trim were painted. somewhere i found the color charts and the matching trim colors (maybe on this site? ) so my 39 is dark green with black fenders and gigilo green pinstriping (light green)
nanneyman #899206 11/25/2012 11:52 AM
First, go to your local parts store and buy a striping kit that puts adhesive tape stripes on your vehicle. Buy one that has two tapes about 3/8 " apart.. Clean the cab around the area you want the stripe. Install the tape on the cab on area to be striped.Peel off the outer layer of the tape, leaving the two stripes on the cab. (it does not matter what colour these are)Take the ends of tape and taper them to show the pointed ends.
Paint between these tapes the colour you want, as soon as the paint is dry, remove the two tapes and you are finished. This process worked for me in painting the Gigilo Green on my '39 Suburban. The stripes end at the point just at the end of the upper wide grille bar. Hope this helps. Stan
nanneyman #899208 11/25/2012 11:54 AM
Sorry, that should read 3/16" apart, not 3/8". Stan
nanneyman #899628 11/27/2012 12:01 PM
Is there a paint code on the body name plate?
Paint combo chart lists the following for 39.
#243 Body: Export Blue Trim: Argent Silver Wheels: Black
#250 Body: Regency Blue Trim: Argent Silver Wheels: Regency Blue
These were the only two Blue paint color Combination's listed for 39 that I could find. However the Dealers would do most any combinatin you wished to pay for.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
