9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
Little background before I get to my actual question. For the front I've got the Flat Out Engineering C4 IFS kit. I already have all of the C4 suspension. For the rear I'm going with the Ride Tech Universal 4 link suspension. This past weekend I got the 9 inch F*rd rear end which is out of a 73 Gran Torino.
My question is there a "better" order for converting the axles or is it simply personal preference? I am thinking that converting the rear suspension will be the better option because I can get the front of my truck to the ride height easier after it is done. Plus part of the instructions for the C4 calls for me to notch the outsides of the frame in order for the cross member to slide up into the frame.
Thoughts?
Carson Holloway
[email protected]
Truck: 1949 Chevy 3100
I am in kinda the same situation. I am putting Fatman's Mustang II IFS and No Limit Engineering Fatbar 4-link in rear.
I am seriously considering starting with the rear first because I am putting an under the bed fuel tank in and I will first make sure it and the rear fit together and then proceed to the front.
Also want to put in a K or X brace and box the frame while I've got it there in the open.
And maybe I just want to avoid fitting motor and trans between radiator and firewall and nothing more...I can't think of much of a difference it makes.
This is a 59 frame, but no incredible differences in the basic ladder frame riveted C-section technology--same as with your 49, for what I know.
Pinion angle you can set in the rear and then weld in engine mounts to match right. So...I don't know that it really makes any difference.
Maybe someone will jump in with some better thoughts, I'm not claiming experience or knowledge here, just some thoughts on how I got to my approach.
R-Bo
1966 GMC 305V6 in the family
Yea i'm pretty much set on doing the rear first due to the notching of the frame in the front. Plus this gives me some time on getting the X or K brace in the middle and also where the motor mounts go.
Thanks for your input.
Carson Holloway
[email protected]
k10 Offline
Don't forget to use weight bags or other weight before you make the final setup. Too many guys get everything all set........and then, oops. The driveshaft is too long, the wheels and tires scrape, the driveline angle is wrong, etc,... you'll have a bed of wood and sheetmetal and maybe a tank of gas to think about. It doesn't sound like the truck will ever haul a load again, so that won't be a consideration.:)
Using weight bags is a good idea. Something I haven't though about. I might not haul a load again that's not to say I won't be putting some luggage in the bed.
Carson Holloway
[email protected]
