1 members (2-Ton), 141 guests, and 2 robots.
Topics128,162
Posts1,056,941
Members48,458
I'm installing a 350 with a 700 R 4 trany in my 42 Chevy 1/2 ton truck and would like to know what water pump should I put on a long or short noise pump, I picked up a new Edlbrock short noise reverse rotation pump at the Moultrie swap meet last weekend at a very good price and would like to use it, put they say that it limits me on room and the pulley set up I will be running, I was going to put on a March set, and the only set they have from Summit it comes with everything, the pump, power steering, alt. and air compressor, what do you all recommend Thanks for any input you may have
Using the high end March system gives you possibilities, but will require you to move a new radiator forward for proper fit. Unless of course you are replacing with a recessed firewall. That adds other issues.
Drew
so I would be better using a long noise pump
Assuming you mean long 'nose' water pump vs. long 'noise' water pump?
I belive with the March system you need about 7 inches clearance from the front of the block to the radiator. March makes some nice stuff, but $$$$$$$
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
David that is what I meant,
I have it figured out and how I'm going to do it with the help of you al, I'm going to order the kit with everything and order a setback firewall, Thanks for the help Drew and David
JC..do you know the rear end ratio? The reason I ask is because I used a 700R4 in my 57' with a 3.55 and now wish I had a 4:10 or had left the TH350 in it.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Dave' it has a 7.625 ring gear with a 3.73 gear and is limited slip posi
I've had low speed vibration issues with the tranny in OD but it goes away at higher RPM. Since I don't want or need to drive 85 MPH I'd rather have the 350 back in it. After super tuning the engine some of the vibration has gone away but I'm still not happy. No vibration at all in direct drive. Hope yours works better with the 3:73. I've heard from a few guys that this is a common complaint with 700's but I fail to see why the General would build something like that.
Happy Thanksgiving.
Dave
