Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#897665 11/18/2012 6:58 PM
I
I Offline
I need a picture of the air cleaner set up for the HVAC brake system located behind the seat on 1960-1966 C60's. It should be behind the driver's side seat. Also, dimensions would be good too. I'm not having any luck finding one and it looks like I will have to fabricate one using a filter approx. the same size. Thanks....
Iron Clad #897954 11/20/2012 2:20 AM
Greetings from the dry side of the state.
Look on you '60, on mine there is a plate that cover a flat spot in the floor panel on the sloped surface towards the door.
Can't say if the plate will be there on your '66 but should see a flat spot where the factory mount hrdro-vac air filter wlouold mount. I beleive Ive got the filter set-up off a '59 C60 that would work . Unless you require the o.e. look you could run the hose to a filter anywhere you want.
BTW, nice fleet!
BC
1960 C60 pasture art
Iron Clad #897974 11/20/2012 8:54 AM
I
I Offline
Thanks BC59. On mine there is a metal pipe coming thru the floor behind the drivers seat in the location you mentioned. When the truck is running, I can put my finger over the pipe and feel the suction.
I'm not looking for O.E., just something that will work. How much would you be asking for your set-up?
Thanks again.
Iron Clad #898073 11/20/2012 6:05 PM
You should only get a brief suction on the breather during brake apply, if it suck with out fluid pressure from master cylinder the Hydro -vac unit has in internal issue.
You could use a cfrankcase breather filter (kind that pops in vaalve cover grommet) from your FLAPs, might be a day or 2 before I located the one I've got rat holed.
BC
Iron Clad #898132 11/20/2012 9:42 PM
I
I Offline
Thanks BC59. You know that actually makes sense, and it does suck air when the brake isn't pressed. So it looks like I will need to rebuild the HVAC system as well? I can say one thing, this truck stops on a dime! I figure for now I'll put the filter on and come back to the HVAC system later. I have other things to do on the truck first, LOL.......Please let me know if you want to part with the filter when you find it.
Iron Clad #898310 11/21/2012 1:30 PM
Just to keep thing straight, what you have is a Hydro-vac booster, no to be confused with the later Hydro-boost (booster run by p.s. pump) or HVAC )heating, ventelation & air conditioning).
BC
Iron Clad #898410 11/21/2012 9:10 PM
I
I Offline
That is correct, my truck has a Hydro-Vac booster. So, no booster run by p.s. pump, etc. .......Thanks.
