2 members (Otto Skorzeny, kades51), 111 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
I currently have a 1955 235 in my 48 Chevy 1/2 ton. It has the original 4 speed with closed driveshaft and original rearend. Is it possible to put a turbo 350 on the inline 6 or should I put in a SBC? what rearend could I put in? I wanna keep the 6 lug chrome steel wheels on it. Im also considering lowering the whole truck a couple inches. Whats the best way? Thanks
fddfdvfdvfvdf For everything needed to connect a late model automatic to a 235 check with Buffalo Enterprises or Bendtsen’s Transmissions. regards, Leon
55-59 rear end will work.
As alluded to above, you'll need an adapter plate to bolt your TH350 to the 235. Your best method of lowering the front would be a dropped axle or removing a couple leafs. The easiest way on the back would be removing a couple of leafs as well.
My 46 GMC on Photobucket
Thanks for the info. Will the trans fit under the floorboard? Its a direct bolt in for the rearend?
