1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I currently have a 1955 235 in my 48 Chevy 1/2 ton. It has the original 4 speed with closed driveshaft and original rearend. Is it possible to put a turbo 350 on the inline 6 or should I put in a SBC? what rearend could I put in? I wanna keep the 6 lug chrome steel wheels on it. Im also considering lowering the whole truck a couple inches. Whats the best way? Thanks | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | fddfdvfdvfvdf
For everything needed to connect a late model automatic to a 235 check with Buffalo Enterprises or Bendtsen’s Transmissions.
regards,
Leon
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | 55-59 rear end will work. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | As alluded to above, you'll need an adapter plate to bolt your TH350 to the 235. Your best method of lowering the front would be a dropped axle or removing a couple leafs. The easiest way on the back would be removing a couple of leafs as well. | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Thanks for the info. Will the trans fit under the floorboard? Its a direct bolt in for the rearend? | | |
