1 members (Erniegp),
47
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 8 New Guy | | New Guy Joined: Nov 2012 Posts: 8 | Looking at buying lowering springs 3" in back and 2" in front. My question is will I have to purchase new spindles or can I just buy the springs??? I was told that I don't and that I can still use the shocks that are on the truck!!
Thanks for input fellow Stovebolters!!
Gotta love the Rust!! The more rust the better!
Old Chevs, old Lanterns, Rust!
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i bet you can still use the old shocks if they are good. they seem to just damper movement and can function if compressed a little more. as far as coils go you hear different info from different people, but i thought 3" was ok with just coils. moore and you would have to buy spindles. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | The stock shocks were designed not to bottom out when the suspension was setting on the bump stops. Therefore as long as you don't modify the rubber bump stops the shocks will work just fine. Lowering springs more than 2" lower than stock on the front will provide very little suspension travel... that's when folks start cutting bump stops for more clearance, that's when you end up needing shorter shocks. As the song goes "One thing leads to another" Hope that helps!  | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | The spindles I've seen lower 2-1/2" AND require switching to disc brakes. BUT, they don't change your geometry like lowering springs. I put 2" lowering springs on mine, front and rear, and use stock shocks...works good after replacing worn out ball joints. I want an anti-sway bar next.
c If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
