0 members (), 91 guests, and 3 robots.
Topics128,095
Posts1,056,067
Members48,433
#896247 11/12/2012 3:50 PM
Anybody use CPP's power steering kit with the Toyota box? I would like the box on the inside and keep the original steering column.
Using the original column won't be an issue. Several suppliers have a bottom bushing to use after you cut it to length. And the double D shape for the end is easy to machine. What's your plan for mounting the pump? I went with a bracket set from Buffalo Enterprises, but I haven't installed it yet.
regards,
Leon
Leon, I always got good advise off of Buffalo in the past so I'm using his vibration damper, pump and mount. The box I plan on getting from CPP.
