2 members (Materman, Nick in Manitou), 79 guests, and 1 robot.
Topics128,072
Posts1,055,906
Members48,429
#896247 11/12/2012 3:50 PM
Anybody use CPP's power steering kit with the Toyota box? I would like the box on the inside and keep the original steering column.
Using the original column won't be an issue. Several suppliers have a bottom bushing to use after you cut it to length. And the double D shape for the end is easy to machine. What's your plan for mounting the pump? I went with a bracket set from Buffalo Enterprises, but I haven't installed it yet.
regards,
Leon
Leon, I always got good advise off of Buffalo in the past so I'm using his vibration damper, pump and mount. The box I plan on getting from CPP.
