1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Anybody use CPP's power steering kit with the Toyota box? I would like the box on the inside and keep the original steering column. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Using the original column won't be an issue. Several suppliers have a bottom bushing to use after you cut it to length. And the double D shape for the end is easy to machine. What's your plan for mounting the pump? I went with a bracket set from Buffalo Enterprises, but I haven't installed it yet.
regards, Leon | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Leon, I always got good advise off of Buffalo in the past so I'm using his vibration damper, pump and mount. The box I plan on getting from CPP. | | |
