0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Will a 700r4 fit in a 47-54 ad truck with stock flat trans cover or does it need the aftermarket style that has the raise area and goes up higher on firewall? im using a 292 6cyl in the stock mounting location
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
I would guess it depends on how high or low the engine is sitting in the engine compartment.
I have a 305 sitting in my 52 panel with a 350 tranny. I was able to use a flat floor tranny cover but I did have to cut a 1/2 inch "quarter moon",at the toeboard.
So, it may depend on how much you have to raise the rear of the tranny to get the engine level.
The 700R4 is the same except it is 4 inches longer.....I switched a 350 out of my 37 and put in a 700R4 and had to cut the driveshaft off 4".
Just info but hope it helps.
I have the motor mount kit for my 292 from langdons and the trans mount from cpp neither one seem to have much if any known adjustment for that unless i need to shim them maybe
Stovebolt CHEVROLET
MY 1949 SUBURBAN
