4 members (Wally / Montana, Otto Skorzeny, baldeagle, joe apple), 72 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#894708 11/05/2012 7:46 PM
OK, so I have all the lines replaced and hooked up to my hydrovac. I am now looking at the vacuum and fresh air lines that come from the HV and go to the Intake Manifold (vacuum) and the fresh air line that coneects to the air cleaner. Being that I have a different motor and air cleaner that is more modern, do I just drill a hole in the base of the air cleaner and connect a fitting for the air line to connect to? Or has anyone else done something different?
1956 Chevy School Bus Superior Body
3B Offline
Hy fclaridge, yes that would be fine, the original air cleaner was mounted behind the seat on cab jobs, I'm not sure where they put them on cowl jobs, under the dash maybe? Hope that helps.
Very much. Thanks again 3B.
