9 members (electors, Tronman, tclederman, Otto Skorzeny, cmayna, klhansen, Bill Hanlon, Peggy M, Gray_Ghost),
95
Mod | | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I am in the process of replacing some rusted out pieces on my 48 1 ton and came across one that I have not been able to identify. Does anyone have any clue what piece this is? http://i1172.photobucket.com/albums/r568/nebuhr/IMG_0051_a.jpg | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | That's the inner to outer cowl panel . They are reproduced and sold by many venders. Sold by Jim Carter Cowl Panel Inner To Outer 1947-Early 1955 Left Side Item # SM107 $55.00 EACH | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | It looks to be the side of the "inner to outer cowl panel" and in order to see the side of this panel means the "Inner cowl Panel" is missing. On these trucks there is an OUTER cowl panel....and Inner to Outer Cowl panel and lastly and Inner cowl panel. | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Thanks for the info GMOINZ. I bought the initial replacement parts from LMC and did not think to look at Jim Carter.
I knew about the "Inner Cowl Pannel"... That was the piece I just removed to replace, and inherently found more parts to replace... imagine that.
Thanks for the help, as always.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Be prepared to be disappointed when you receive that part. It will take some tweaking to make it work. Pretty much the same story with many of the repair panels. ...example... ...example... | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | I noticed that the panels I have already bought do not really match as well as I would like them too. Selective cutting and welding has gotten me by so far. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | This might help fit the new inner outer panel.I got a new cowl and inner outer from Jim Carter and made this change and sent them back to him hoping that they would make this simple change so that the inner outer would fit right from the vendor but I never heard back to bad ,I did talk to Jim when I was in Kansas city but no change has been made.So I guess We will continue to do it ourselves. http://s559.photobucket.com/albums/ss39/sparky52/inner%20outer/Pete
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thats just the lower section of the inner outer on some trucks just the lower section of the inner outer and the cowl are rusted thru thats why they sell them that way.
Pete | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Sorry for letting this go so long.
Was the inner to outer cowl originally spot welded to the inner cowl?
What is the proper way to attached the inner cowl to the floor pan? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Was the inner to outer cowl originally spot welded to the inner cowl? Yes it was spot welded ...pic... ...pic... ...pic... What is the proper way to attached the inner cowl to the floor pan? ...pic... It welds to the floor pan/rocker. There should be a flange at the bottom of the inner panel ...pic... ...pic... Here is the kick panel after reworking it to fit ...pic... The factory assembly manual has very good detail on this | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Thanks DADS50, you seem to be helping me out a lot lately.
How did you attach the inner to outer cowl to the inner cowl? I do not have any means of spot welding at the moment. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you have no way to spot weld then maybe consider 3M 8101 Structural Panel adhesive and some rivets...
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | How did you attach the inner to outer cowl to the inner cowl? I do not have any means of spot welding at the moment. I welded it. I cut the old spot welds out with a spot weld cutting tool. welded it back in with a Lincoln Handy MIG From your first post it looks like your inner to outer is not in to bad of shape. you could just patch the part you have circled in place then replace the kick panel. | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | For some reason repairing the part slipped my mind...
There are some other parts around the front fender that I want to clean up and paint, but that would definitely save me some money. Thanks Again. | | |
