3 members (55shaker, Otto Skorzeny, GMCJammer51), 97 guests, and 0 robots.
Topics128,050
Posts1,055,646
#89443 04/19/2005 3:52 AM
1 Offline
Have any of you used the type 2 harness from Jim Carter? I am gong to rewire my 51 ,3100 and also change it to an alternator. I've got a gift certificate burning a hole in my pocket and thought if this is a good harness this would be a good place to use it. I think it sells for about 140.00 Thanks.
#89444 04/19/2005 11:53 AM
2 Offline
Used it and it and like it.
#89445 04/20/2005 1:19 AM
1 Offline
One more question, As I said I am going to go to an alternator and the bracket that is sold in the suppliers catalogues looks to be kind of spendy . Is there a bracket on any particular old car or truck that I could pick up at the local junk yard that would work on a 235, or can one be easily bent or reformed from another bracket. Thanks
#89446 04/20/2005 2:35 AM
yes - can't recall right off which, but a later GM 6 [maybe even last of the 235's] has an alternator stock, and the mount bracket fits right in to replace the generator - found one that fit my 46 GMC 228 fine - take your bracket for reference and just look at any late 235, 230, 250, 292 in the yard to find a fit
#89447 04/20/2005 3:48 AM
Anonymous
Unregistered
Anonymous
Unregistered
My 64 has a factory alternator and the bracket looks like it could work fine on my 235 in my 60.
#89448 04/20/2005 3:52 AM
Anonymous
Unregistered
Anonymous
Unregistered
I forgot to mention that my engine in my 64 is a 230.
#89449 04/25/2005 10:04 PM
Junior Member
Junior Member
1951 Elmer,
I just put a 63 amp, three-wire GM type alternator on my 54 3100. I modified the stock generator brackets to work. The bottom braket was slotted to connect the two holes in it. I then used 3/8" allthread and some nuts and washers to secure the bottom mount. The top mount had to be flipped over with no other mods. Looks pretty good and feels very secure.
#89450 04/25/2005 11:52 PM
1 Offline
Thanks I will try that.
#89451 04/26/2005 5:47 AM
Does that Type 2 harness include all the wiring up to the guages? Are there any other electrical items that need to be bought?
"Happiness equals reality minus expectations" - Tom Magliozzi
#89452 04/26/2005 12:07 PM
2 Offline
Yes the harness includes the wiring to the guages. If I recall correctly I only had to buy the harness to the head lights extra. I did this a couple of years ago. It went in pretty easy after I laid it out on the floor to get a better idea what went where.
