1 members (crenwelge),
151
Mod | | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89443 04/19/2005 3:52 AM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Have any of you used the type 2 harness from Jim Carter? I am gong to rewire my 51 ,3100 and also change it to an alternator. I've got a gift certificate burning a hole in my pocket and thought if this is a good harness this would be a good place to use it. I think it sells for about 140.00 Thanks. | | |
#89444 04/19/2005 11:53 AM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Used it and it and like it. | | |
#89445 04/20/2005 1:19 AM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | One more question, As I said I am going to go to an alternator and the bracket that is sold in the suppliers catalogues looks to be kind of spendy . Is there a bracket on any particular old car or truck that I could pick up at the local junk yard that would work on a 235, or can one be easily bent or reformed from another bracket. Thanks | | |
#89446 04/20/2005 2:35 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes - can't recall right off which, but a later GM 6 [maybe even last of the 235's] has an alternator stock, and the mount bracket fits right in to replace the generator - found one that fit my 46 GMC 228 fine - take your bracket for reference and just look at any late 235, 230, 250, 292 in the yard to find a fit
Bill | | |
#89447 04/20/2005 3:48 AM | | Anonymous Unregistered | | Anonymous Unregistered | My 64 has a factory alternator and the bracket looks like it could work fine on my 235 in my 60. | | |
#89448 04/20/2005 3:52 AM | | Anonymous Unregistered | | Anonymous Unregistered | I forgot to mention that my engine in my 64 is a 230. | | |
#89449 04/25/2005 10:04 PM | Joined: May 2003 Posts: 13 Junior Member | | Junior Member Joined: May 2003 Posts: 13 | 1951 Elmer,
I just put a 63 amp, three-wire GM type alternator on my 54 3100. I modified the stock generator brackets to work. The bottom braket was slotted to connect the two holes in it. I then used 3/8" allthread and some nuts and washers to secure the bottom mount. The top mount had to be flipped over with no other mods. Looks pretty good and feels very secure. | | |
#89450 04/25/2005 11:52 PM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | | | |
#89451 04/26/2005 5:47 AM | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | Does that Type 2 harness include all the wiring up to the guages? Are there any other electrical items that need to be bought?
"Happiness equals reality minus expectations" - Tom Magliozzi
#89452 04/26/2005 12:07 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Yes the harness includes the wiring to the guages. If I recall correctly I only had to buy the harness to the head lights extra. I did this a couple of years ago. It went in pretty easy after I laid it out on the floor to get a better idea what went where. | | |
