9 members (51sub, farmallb, 1955 1 Series, walter74, TexasA&M48Truck, baldeagle, dt235sd, Charles in CA, 32Fordpuchoptop),
30
Mod | | | Forums66 Topics128,005 Posts1,055,256 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I have installed a 235 in my "52" truck and now installing the original 216 radiator. I have new mounting pads but the original mount had three pieces on each side which appear to be shims. Would that be what they are? I have no sheet metal installed yet, just the engine on the frame so I can not tell how it all will line up. I went with the short water pump. Will I have a problem cooling due to the fan being somewhat lower on the radiator then original.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, metal shims were used under the radiator, in addition to rubber pad/pads. Those shims would assist in obtaining proper front sheet metal alignment.
Many people use the short-shaft water pump successfully. My guess is that if the block is internally clean, and coolant flows freely throughout the block/head, you will have no problems. However, many people think that using a water pump relocation plate is the ideal configuration, since it places the water pump in the correct orientation to the radiator.
