0 members (), 64 guests, and 4 robots.
Topics128,014
Posts1,055,325
Members48,419
#89305 10/26/2004 4:19 AM
Hi all,
Does anyone know of a source for an original two speed toggle style heater switch for a 53/54 fresh air heater? (12 volt) None of the online vendors seem to have any.
Steve
#89306 10/26/2004 7:09 AM
I would say the auto parts section of E-Bay.
I found one for my '51 6V. The switch will work
with either 6 or 12. It's the fan motor in the
heater you will have to worry about.
#89307 10/26/2004 9:34 PM
you might try napa. i not sure when you say toggle, my 54 has a brown turn knob with a restat. brothers.com has those. so does jim carter, chevy duty. hope this helps. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#89308 10/26/2004 11:22 PM
The rotary knobs are aftermarket. The factory switch is a three-position toggle with "Air" "Heat" or "Vent" (I think) stamped on the switch.
1954 GMC De Luxe COE
#89309 11/07/2004 3:36 AM
Vintage Auto Parts (www.vapinc.com) sells them, or at least used to do so. I doubt if they would go for less than $40
#89310 11/10/2004 10:23 PM
Junior Member
Junior Member
Thanks everyone for the info. This will give me something to work on this weekend. Ohem tell your wife thanks for the tip. I've learned a long time ago that women can think faster than men.
thankyou again
clint
#89311 11/10/2004 10:37 PM
Yup, Vintage had them, but when I stopped by the fella cationed me not to use the switch-not cheap- in a 12 volt system.
51 Chevy 1/2 ton-Restored
46 GMC 1 1/2 ton-Farm Fresh
#89312 11/21/2004 4:45 AM
Junior Member
Junior Member
OK, can you use the original switch with a 12 volt system? I have a 12 volt motor in the heater. Will the original switch work or do I need a voltage reducer in front of the switch?
