9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89305 10/26/2004 4:19 AM | Joined: Oct 2003 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 94 | Hi all,
Does anyone know of a source for an original two speed toggle style heater switch for a 53/54 fresh air heater? (12 volt) None of the online vendors seem to have any.
Thanks, Steve | | |
#89306 10/26/2004 7:09 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I would say the auto parts section of E-Bay. I found one for my '51 6V. The switch will work with either 6 or 12. It's the fan motor in the heater you will have to worry about. | | |
#89307 10/26/2004 9:34 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | you might try napa. i not sure when you say toggle, my 54 has a brown turn knob with a restat. brothers.com has those. so does jim carter, chevy duty. hope this helps. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#89308 10/26/2004 11:22 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The rotary knobs are aftermarket. The factory switch is a three-position toggle with "Air" "Heat" or "Vent" (I think) stamped on the switch. | | |
#89309 11/07/2004 3:36 AM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Vintage Auto Parts ( www.vapinc.com) sells them, or at least used to do so. I doubt if they would go for less than $40 | | |
#89310 11/10/2004 10:23 PM | Joined: Nov 2004 Posts: 3 Junior Member | | Junior Member Joined: Nov 2004 Posts: 3 | Thanks everyone for the info. This will give me something to work on this weekend. Ohem tell your wife thanks for the tip. I've learned a long time ago that women can think faster than men.
thankyou again clint | | |
#89311 11/10/2004 10:37 PM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Yup, Vintage had them, but when I stopped by the fella cationed me not to use the switch-not cheap- in a 12 volt system.
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
#89312 11/21/2004 4:45 AM | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | OK, can you use the original switch with a 12 volt system? I have a 12 volt motor in the heater. Will the original switch work or do I need a voltage reducer in front of the switch?
Thanks | | |
