8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Since my 1942 dump has been converted to 12 volt, I really do not see myself useing the factory location under the floor. Thinking about using a box on the frame rail just behind pass side of cab sort of like the big rigs have. Has anyone else moved their battery to a different location? PS, I don't want it on the firewall. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | what's the difference between the stock location and a foot behind the stock location?
Bill | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | The original tray won't accept a 12 volt, easier in and out as this truck won't be a daily driver ,I don't like leaving batteries in my trucks when not being used. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | alltruck72, Another thing to take into consideration is that when you locate the battery farther from the starter,the more resistance you have in the wires,resulting in less current to your battery,and more heat,generated from the resistance in the cables. I had a cable fall on the ground-on-fire,from an over-length jumper-wire,although it was on a COF4070B IHC TranstarTwo.,equipped with two 12V batteries,335 Cummins Fuller RTO9510,10-speed,twin Rockwells with 4:11's B.T.W.-It also "cashed the starter!-EXPENSIVE!! B.T.W... the cable was less than 4' long. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | Beleive it or not , my truck came from the factory with the battery mounted behind the cab, covered with a metal box. Mine is a 45 GMC 400 series truck. According to the master parts book, that setup was exclusive to the 400 & 450 series trucks. | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Thanks Jeff, Thats what I've seen before in pictures, I quess your truck is the proof! | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Thats perfect, Thanks for the pic Paul. | | |
