0 members (), 79 guests, and 1 robot.
Topics128,049
Posts1,055,740
#892154 10/25/2012 11:50 PM
I am in the beginning stages of planning what I want to do with my 38 pickup. I intend to make it into a custom and have been thinking about making it a dump truck just to be different. I would be making my own bed so I could keep it lighter, but I need some good pictures and dimensions to work from. Anyone able to help, I can't find much online.
Ageingrodder #892247 10/26/2012 11:29 AM
back yard wrench turner
Try using Google images search for pictures. It will show lots and lots of them.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wayne67vert #892308 10/26/2012 5:28 PM
I did and there just wasn't anything that I found with much detail. What did you use for the search criteria?
Ageingrodder #892310 10/26/2012 6:13 PM
Professional Novice
Frank50 #892311 10/26/2012 6:22 PM
Thanks Frank50. I have that manual but there is nothing about dump truck beds. I assume these were probably manufactured by some other than GM and added later. I'm looking for detail on the bed in this link http://www.stovebolt.com/gallery/bison_jeff_1938.html . If all else fails, I guess I'll wing it.
Ageingrodder #892317 10/26/2012 7:28 PM
3B Offline
Hy Ageingrodder, what you want to access is called the "Silver Book" I don't know how far they go back, but I know they've been around since the early 50s for sure. This is the book that had pictures and descriptions of the equipment aftermarket suppliers could supply/install on your new truck, hope that helps.
Ageingrodder #892321 10/26/2012 7:33 PM
also note if you want a dumper, a good place to start would be to find all the hardware, including a PTO trans to run it, what you come up with for a pump and ram[s] will dictate some of the design
Ageingrodder #892328 10/26/2012 8:08 PM
here is what google images shows for dump bed kit:
https://www.google.com/search?num=1...70.743.12.12.0...0.0...1ac.1.LkzWL0wFnlA
If you click on the images it will show where they came from. There are several kit companies showing photos of their products.
Wayne
1989 Silverado
Ageingrodder #892458 10/27/2012 10:45 AM
You guys are great. I will probably make the bed run off a hydraulic pump versus PTO. Probably never have any real load in it. mostly show.
