9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 9 New Guy | | New Guy Joined: Oct 2012 Posts: 9 | I am in the beginning stages of planning what I want to do with my 38 pickup. I intend to make it into a custom and have been thinking about making it a dump truck just to be different. I would be making my own bed so I could keep it lighter, but I need some good pictures and dimensions to work from. Anyone able to help, I can't find much online.
| | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | Try using Google images search for pictures. It will show lots and lots of them. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2012 Posts: 9 New Guy | | New Guy Joined: Oct 2012 Posts: 9 | Try using Google images search for pictures. It will show lots and lots of them. I did and there just wasn't anything that I found with much detail. What did you use for the search criteria? | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 |
Professional Novice
| | | | | Joined: Oct 2012 Posts: 9 New Guy | | New Guy Joined: Oct 2012 Posts: 9 | Thanks Frank50. I have that manual but there is nothing about dump truck beds. I assume these were probably manufactured by some other than GM and added later. I'm looking for detail on the bed in this link http://www.stovebolt.com/gallery/bison_jeff_1938.html . If all else fails, I guess I'll wing it.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ageingrodder, what you want to access is called the "Silver Book" I don't know how far they go back, but I know they've been around since the early 50s for sure. This is the book that had pictures and descriptions of the equipment aftermarket suppliers could supply/install on your new truck, hope that helps. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | also note if you want a dumper, a good place to start would be to find all the hardware, including a PTO trans to run it, what you come up with for a pump and ram[s] will dictate some of the design
Bill | | | | | Joined: Sep 2010 Posts: 1,705 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,705 | here is what google images shows for dump bed kit: https://www.google.com/search?num=1...70.743.12.12.0...0.0...1ac.1.LkzWL0wFnlAIf you click on the images it will show where they came from. There are several kit companies showing photos of their products.
Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Oct 2012 Posts: 9 New Guy | | New Guy Joined: Oct 2012 Posts: 9 | You guys are great. I will probably make the bed run off a hydraulic pump versus PTO. Probably never have any real load in it. mostly show.
