5 members (WICruiser, TUTS 59, Napco Man, Ponchogl, stlcardinalsguy), 56 guests, and 2 robots.
Topics128,035
Posts1,055,564
#730572 03/17/2011 12:01 AM
Check this out bolters. I work at the heavy equipment shop for the Border Patrol and we had this bus up on the lift and I couldnt help but notice this setup on the front axle. Older mechanic working on it said it might be able to be done to an AD truck since he used to own one. Just never seen anything like it. Hmmm pix headscratch
Rear view
http://i295.photobucket.com/albums/mm128/lt1bubble/0648a962.jpg
Front view
http://i295.photobucket.com/albums/mm128/lt1bubble/7f2dfb8d.jpg
http://i295.photobucket.com/albums/mm128/lt1bubble/964752cd.jpg
http://i295.photobucket.com/albums/mm128/lt1bubble/8624ba61.jpg
That looks like a nice front suspension, what kind of bus, it doesn't look all that big?
Here's how I put air springs on my AD truck
http://rides.webshots.com/photo/2324065910080251109mrqkVs
Pretty simple to do, still have the leaf springs but they are weak enough that the bags bottom out with no pressure in them.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Its a 2001 Bluebird, its actually kind of a big bus. Its used to transport criminals/aliens bcuz it has stainless steel seats and cages. I think its a nice setup
How does your truck ride with the airbags inflated?
Seems like it rides nice what little I've driven it, but it's not really on the road yet.
I wasn't so much looking for airbags like many folks do, to make it low or a smooth ride... I simply wanted helper springs to get it back up to ride height and have some adjustment for different loads. They do that, now if the ride is really nice because of it that's an added bonus.
Grigg
---All pictures---
Watson and Chalin used to make them, but I don't see them in their catalog anymore. It looks like a Watson and Chalin unit. Ridewell still makes a unit like this. http://www.ridewellcorp.com/Web/Site.nsf/ID/RAS238
I would assume Airlift and Air Ride do also. They both have a lot of kits though. I built my own from parts from them both.
Thats crazy how they got so many styles of setups but I guess my real question is why hasnt anyone done this to an AD truck?
Apparently its possible with a solid straight axle!
I rcall someone asking about doing that a while back. It may not have been here, as I was also a regular on the Gearz site at the same time, but I don't see why it couldn't be done. Using the front suspension from a 2wd Jeep late '80s/early '90s Jeep Cherokee might be one way to go, as they are a 4 link coil spring suspension. Replace the coils with airbags. Suspension from the 4x4 models and the '94-'02 Ram 4x4 could also work, same design exept with a drive axle instead of a tube axle.
Bill Burmeister
I totally agree with you Longbox55. All youre really doing is eliminating the leaf springs and using an air bag instead. Just have to fab up some type of 4 link or even 3 maybe? headscratch
I think before going to the trouble to fabricate a front air suspension figure out what for...
What do you hope to gain by doing it, will you actually gain anything, and is it worth it?
Leaf springs are pretty good at their jobs.
Grigg
---All pictures---
Cool! Thanx for the input! cool
Air ride on the drive axle does a lot more than air ride on the steering axle. Air ride has been tried on the steering axle for many years and very little has been accomplished. The first steering axle failure I can remember was when GMC offered it on their cracker box cabs in the 60's. Owners retrofitted them with springs. Air ride on the drive axle is great. And on trucks with a tilting hood, air ride on the cab is great too.
Grigg
How did that work out for you did you use it to actually lift the front up from being low?
Stovebolt CHEVROLET
1949 Chevrolet Suburban
Non stovebolt CHEVROLET
1958 Impala Convertible
1963 Impala Convertible
MY 1949 SUBURBAN
So far so good.
Yes, I put a little air in them to pick it up to normal height. Plan to use automatic leveling valve eventually, it will compensate for load and keep the same height.
Grigg
---All pictures---
So far so good.
Grigg
Did you buy a kit if so any info on it or did you fab it all yourself?
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Msde it muself, RE5 bags from slam specialtys I think.
---All pictures---
Ok cool thanks do you get alot of lift out of it i was going to IFS my truck but with the expense i think im going to keep it straight axle but i want it slammed low but yet still have air ride
Stovebolt CHEVROLET
MY 1949 SUBURBAN
Cant help you there. Don't see how what I have is any lower than stock or how you would do so, not and have the bags between axle and frame..
---All pictures---
On an AD truck the front spring packs are relatively flat. Not alot of room between frame and axle. Going outboard creates a problem with steering clearance. Not to menting the front frame being tapered, it would be a fabrication nightmare. If one wants to jump in the airbag game, it'll be headfirst without a life vest.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
