3 members (1955firstseries, Roy Rodgers, elhippie64), 75 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#890 11/15/2004 8:00 AM
Well first off I must say thanks to the guys here. They are the best. Next question. I have my 49 GMC and am upgrading to power steering. I was going to keep the stock column but thought I would see if the column from my donor truck would work. It's a 77 GMC 1/2 ton. Will the column from that work? I have read that the best ones to get are from 70's vans, but might try the one from my 77. Thanks.
kskt4
Mine came from a '75. Took some fabriction to make work, but I like it now that it's in there,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
It might be easier to use the '77 column than the original.
Using the original requires cutting the column and shaft and locating a bearing to support the shaft. And then attaching to the end of the original shaft to connect to the new steering box.
My current thought is to look for a way to put the original wheel on a later column. Of course I plan to gain a turn-signal switch, automatic column shift and tilt wheel in the process.
Thanks guys,
I will look into using the 77 column.
kskt4
