2 members (Gray_Ghost, 50Chevy3100), 71 guests, and 1 robot.
Topics128,056
Posts1,055,800
#890651 10/19/2012 10:17 PM
How do I tell for sure whether my truck is a 1 1/2 ton or a 2 ton ?
I believe it has a 12' bed and it is a dump bed as well.
Ive loaded pics up in the dity gallery but they havent made it yet to the main gallery. I could load another pic if necessary.
Thanks, troy
Troy
1963 Chevy C60
Big Red Chevy
1951 GMC 453 Series 3-Ton Army Truck
Red63 #890666 10/19/2012 11:40 PM
troy,The 60 Series would definitely be a 2-ton. Check for gross weight plate on driver's side door jamb. Yours should gross 18,000,or more. My 2nd-Series '55 6500 grosses at 18,000. hope this helps.
Mo' Tater
wetwilly5757 #890735 10/20/2012 12:21 PM
Yes, it helps very much...Thank you wetwilly smile
Troy
1963 Chevy C60
Big Red Chevy
Red63 #890789 10/20/2012 5:06 PM
Let us know more about your truck and yes we love pictures.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Red63 #891331 10/22/2012 6:26 PM
Red63,WELCOME to the "Stovebolt"! I've gotten so much help for my truck on this site!You won't believe the great people all over the world that LOVE our trucks!! Please submit some pics,as we all love 'em! As stated in the D.I.T.Y. gallery,the way to submit pic's (and/or video's),is by suscriving to a photo hosting site,such as "Photobucket","webshots",etc. There's several sites available,and the up-loads are free! "Stovebolt" doesn't like anyone to post photo's directly into their link(s),though. The reason is because it takes up too much space,and ,if someone has already viewed your truck several times,it may get redundant, and generally slows-down the site,for other users. This site is the Bomb!! F.Y.I... If you want to buy a part,there's a special "board" for that! Same goes with.. Trucks For Sale,Trucks Wanted,Parts For Sale,etc,etc. This just helps the moderators from having to go back and correct our mistakes,and post our stuff in the correct categories. And make sure to check-out the "Galleries"!! Welcome,and have FUN!!
Mo' Tater
Thank you for sharing... I truly love this site too and cant wait to get my rig in the gallery. I did upload three pics in the dity through photobucket. They are there listed under 63c60 i believe, uploaded in july. Anyway, i could load some more too when i get to where I can.
Again, thanks alot smile
Troy
1963 Chevy C60
Big Red Chevy
Red63 #891363 10/22/2012 8:37 PM
Wetwilly, correction on the upload date of July... I loaded three pics to the dity
on June 27.... Not that it makes much difference smile
Troy
1963 Chevy C60
Big Red Chevy
Red63 #891504 10/23/2012 4:02 PM
I've previously posted about this 1-1/2 - 2ton thing but looks like it's time to do it again. For everyone's information there really is only one way to determine the capacity of a truck chassis and this is by it's GVWR and GAWR. That's GrossVehicle WeightRating and GrossAxleWeightRating. That describes how it was built and what the builder claims/intends as capacity rating. Forget that it is seldom considered when loading a great many trucks.
The terms 1 ton, ton & half and two ton are hold overs from the old days of the 30's - 40's and referred to the capacity rating of the front axle. So if your truck was a "2 ton" it meant the front axle could support the trucks's weight and a load of 2 tons. Now that isn't much but one must absolutely get a 40's mindset going on if this is to make any sense to you. It does to me but I'm older than most here it seems. That allows me to remember the size of delivery/farm trucks from earlier times and relate it to todays chassis. Nowadays the capacities of chassis are considerably higher than from those times.
Example: Wetwilly says his 55' "two-ton" is rated at 18,000 GVWR. Let's see how that compares:
Today that would equate to a F&%d F450-F550 chassis or Navistar TerraStar which has 19'.5 wheels and a low profile as compared to yesteryears trucks which we consider as "real trucks" while newer ones are kind of puny looking.
The best way to make a comparison is to look at the Class rating. Today we have trucks divided into the following classification by GVWR:
Class I 0-6000 lbs
Class II 6001-10000
Class III 10001 - 14000 (F350-GM3500-3500 Ram)
Class IV 14001 - 16000 F450-4500 Ram
Class V 16001 - 19500 (F550-5500 Ram- Isuzu NPR
Class VI 19501 - 26000 F650-F750
Class VII 26001 - 33000
Class VIII 33001 - + (all tandem trucks and heavy single axles)
As stated a great many of todays trucks and the older ones too are overloaded. I've often done it myself and with no repercussions worthy of report so there is little of anything to be learned from the old terminology. So in the future if you want to understand your truck then you may refer to this info and hopefully we can all begin to use the current terminology so that the "what did I buy" questions can be laid to rest. And what you can load/haul will begin to make some sense.
Edit: Dave's info here was made into a helpful Tech Tip. Appreciate the work he put into this! thumbs_up
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
