4 members (Danielbolt, Ponchogl, 216wny, 1 invisible), 151 guests, and 2 robots.
Topics128,157
Posts1,056,874
Members48,456
#89053 03/31/2004 8:53 PM
I've completed my rewire project to a 12 volt alternater system and it came out pretty nice. My original heater and defroster seams to run fine with 12 volts. I have these heater and defrost swithes as shown below that I want to use (those kind of switches are like gold!). Will 12 volts ruin these? I guess I can step them down if I have to but I want to keep it simple. And what size fuses should I use? [img]http://img.villagephotos.com/p/2003-9/378428/switches.jpg[/img]
Bondo Artiste
Bondo Artiste
John, I also have the same question. I have a N.O.S switch on the way and I do not want to fry this thing. There is a old timer's auto electrical shop here in town, when I get my switch I am gonna swing in have them look it over and give the scoop on running this thing on 12 volts. I also hope someone here will chime in and give us some more info.
Your truck is looking real sweet! Keep up the good work.
~ Phillip
Go ahead and give it a try. Let us all know how it works. :-)
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Haven't gotten around to dealing with mine yet, but if the original motors are good, I'm going to use a voltage reducer to get it down from 12 to 6 volts. If the motors are bad, I'll replace them with 12 volt ones and get the 12 volt repro switches. I'm debating whether to use separate switches for the heater and defroster or just run them both from the same switch, but I guess using two switches would be the best bet.
As for fuses, I'm planning on using 20 amps which is what my trucks uses for the heater.
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
