1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#88969 11/06/2002 4:44 PM
i have a 51 1/2 ton and the turn signals don't
flicker they just stay on. and idea what this could be
THE MARKER LIGHT....
I'LL CHECK THE FLASHER AND BULBS AGAIN AND SEE WHAT HAPPENS
THANKS GUYS
#88970 11/06/2002 4:56 PM
Check your flasher, it's probably bad.
#88971 11/06/2002 5:21 PM
When you say the turn signals don't flicker they just stay on are you talking about the indicator lights on the switch or the actual marker light?
If I remeber this correctly:
The indicator light will stay on constantly when one of the marker light bulbs are burned out.
The indicator light will not light when the flasher is bad.
If I have this backwards someone please correct me, thanks.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#88972 11/06/2002 6:13 PM
Light and directional problems are usually solved with a little patience and investigation. Are your tail light housings grounded properly to the frame. Is the flasher unit working properly ? If you have a 6 volt truck, are you sure the flasher is 6 volt and not 12 ? Check around and let us know what you find..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#88973 11/06/2002 11:20 PM
you have received some good tips, I also have a 52 chevy with aftermaket directionals, I had some problems recently and after going crazy trying to check things, my problem turned out to be a inline fuse that I did not noticed, could you be so lucky? good luck, Fred
Redryder pix
My Hotrod
