8 members (chevy51truck, Gdads51, dt235sd, Otto Skorzeny, JW51, MickeyP, LAROKE, TUTS 59),
56
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,698 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88969 11/06/2002 4:44 PM | Joined: Nov 2002 Posts: 33 Member | | Member Joined: Nov 2002 Posts: 33 | i have a 51 1/2 ton and the turn signals don't flicker they just stay on. and idea what this could be
THE MARKER LIGHT.... I'LL CHECK THE FLASHER AND BULBS AGAIN AND SEE WHAT HAPPENS THANKS GUYS | | |
#88970 11/06/2002 4:56 PM | Joined: Jul 2002 Posts: 27 Member | | Member Joined: Jul 2002 Posts: 27 | Check your flasher, it's probably bad. | | |
#88971 11/06/2002 5:21 PM | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | When you say the turn signals don't flicker they just stay on are you talking about the indicator lights on the switch or the actual marker light?
If I remeber this correctly: The indicator light will stay on constantly when one of the marker light bulbs are burned out.
The indicator light will not light when the flasher is bad.
If I have this backwards someone please correct me, thanks.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#88972 11/06/2002 6:13 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Light and directional problems are usually solved with a little patience and investigation. Are your tail light housings grounded properly to the frame. Is the flasher unit working properly ? If you have a 6 volt truck, are you sure the flasher is 6 volt and not 12 ? Check around and let us know what you find..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#88973 11/06/2002 11:20 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you have received some good tips, I also have a 52 chevy with aftermaket directionals, I had some problems recently and after going crazy trying to check things, my problem turned out to be a inline fuse that I did not noticed, could you be so lucky? good luck, Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
