5 members (Guitplayer, 50Chevy3100, Otto Skorzeny, Hotrod Lincoln, TUTS 59), 154 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#889058 10/12/2012 11:38 PM
0
0 Offline
I've got a '39 Coupe with a '56 235 and have put '57 - '58 Chev gears into the '39 case and converted it to open driveshaft. I've just broken a tooth off and want to go to a Saginaw 4 speed because I can get a floor shift from Patricks for it. Will this fit without cutting the gearbox crossmember. I still have the master cylinder mounted to this. I'm looking for a '48 - '54 pickup bellhousing as we speak.
0hixul6 #889067 10/13/2012 2:22 AM
1937-39 pass transmissions are the shortest Chev transmissions I have ever seen. I Saginaw will be much longer.
My Blog
0hixul6 #889078 10/13/2012 7:57 AM
It will take some fabrication to make it work.
0hixul6 #889126 10/13/2012 1:38 PM
H Online: Content
The Saginaw case has the same bellhousing bolt pattern as the SM-420 and other late model transmissions such as the 55-up passenger car and truck 3-speed boxes. I'm pretty sure it won't bolt up to your bellhousing without some adapting.
0
0 Offline
I'll use the '48 - '54 pickup bellhousing that I'm told will bolt to the motor, has the engine mounts at the front which I've got now and has the late gearbox bolt pattern.
0hixul6 #889213 10/13/2012 9:29 PM
You are correct on all of those points, although 54 is not the last year you could use. 1948-59 should work.
A 1955-62 pass 235 bellhousing would also work if you are using key start.
My Blog
0hixul6 #889527 10/15/2012 11:59 AM
My 47 3100 had the 216 with the 3 speed on the floor. I have a 54 235 that I wanted to use a Saginaw 4 speed with. The saginaw would not fit the narrow bellhousing that I had for the 216.
0hixul6 #889531 10/15/2012 12:25 PM
kswillie,
If you use a 1948-53 truck bellhousing it will all bolt up.
My Blog
