Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#881153 09/08/2012 8:13 PM
Has anyone shortened a steering column on a 1951 3600?
Dkelly #881163 09/08/2012 8:50 PM
You may want to repost this to the driveline forum for more exposure.
Dkelly #884097 09/22/2012 10:24 AM
DKelly,
Column Saver Kit is what Im going to use. This might help in your adventures.
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
Dkelly #888106 10/09/2012 9:37 AM
I don't see why you couldn't just chop a couple inches from the middle of the shaft and reweld and then an equal amount from the outer column.
Dkelly #888111 10/09/2012 9:54 AM
If you're referring to an advanced design truck, I replaced the shaft on mine due to steering wheel thread damage from previous owner. I got a new shaft from (I think) Jim Carter. There is a weld joint near the bottom of the shaft near the gear. I carefully cut and rewelded the joint. If you weld, be sure to clamp it in exact alignment and let it cool completely before unclamping.
I didn't do anything with outer case, but procedure is the same.
Dave Evans
52_3100
