0 members (),
64
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 17 New Guy | | New Guy Joined: Jul 2012 Posts: 17 | Has anyone shortened a steering column on a 1951 3600? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | You may want to repost this to the driveline forum for more exposure. | | | | | Joined: Feb 2009 Posts: 269 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 269 | DKelly, Column Saver Kit is what Im going to use. This might help in your adventures.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I don't see why you couldn't just chop a couple inches from the middle of the shaft and reweld and then an equal amount from the outer column. | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | If you're referring to an advanced design truck, I replaced the shaft on mine due to steering wheel thread damage from previous owner. I got a new shaft from (I think) Jim Carter. There is a weld joint near the bottom of the shaft near the gear. I carefully cut and rewelded the joint. If you weld, be sure to clamp it in exact alignment and let it cool completely before unclamping. I didn't do anything with outer case, but procedure is the same. Dave Evans 52_3100 | | |
