| | | Forums66 Topics128,113 Posts1,056,616 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | What highway speed can I expect with an eaton rear end, 5.29 ratio, 22.5 tires, 235 ci engine, and original 4 speed tranny? Thanks much | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Use the Search area at the top pf the page and type in Speed Calculator. It will list some options to figure it out. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | http://www.onlineconversion.com/bigger_tires.htm9R22.5 tires which should fit nicely in the 51 fenders are 38" tall The original 4 speed is a direct drive; 1:1 ratio in high gear. A later 235 is comfortable on the highway at a constant 2,400-2,500 RPM in my experience. Plug all that in and it spits out 53 MPH Grigg | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Thanks Grigg, I was trying the calculator but did not have all the pertinent data. I did not know the transmission ratio at 4th gear. I do have a 1955 235 ci engine. I can get this rear end differential circa 1994, with disk brakes and low mileage for $350.00.
Another question would a v8 engine make a difference? (replacing the 235 ci ) Chris | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Disc brakes on the rear in my experience always came with disc on the front too. Never seen disc on the rear and drums on the front (factory) and not sure it's a good idea to do so. Are you also considering disc brakes up front?
Depending on the engine you swap it will/can have a different comfortable operating RPM.
Grigg | | |
