| | | Forums66 Topics128,078 Posts1,056,029 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 3 New Guy | | New Guy Joined: Oct 2012 Posts: 3 | We've got a 12" adjustable crescent wrench (made in China). The screw that holds in the spiral adjuster somehow fell out. Would anyone know where I could get another screw? It seems a shame to throw the wrench away when all it needs is a 5 cent screw. It seems to be a 1/4" machine screw about 2" long but the thread isn't 20tpi.
Thanks. | | | | | Joined: Jul 2010 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 66 | It's probably metric. 6mm? The hardware store probably has fine or coarse pitch. Dave Evans 52_3100
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | if it gets down to it you can always drill it out and tap to a common machine screw. better than tossing it or driving into town for a metric cap screw. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Find a bolt with the right threads at the hardware store if you do not have one in your "junk pile" and then cut it off to length...then cut/grind a cross section in it to use a slotted screwdriver. Worked for me. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | weld a nail in its place...need smooth surface for the knurled adjuster wheel... | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Driving into town? Does he live in the woods?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | i have rebuilt several exactly how Achipmunk said. when my dad throws out a old crescent wrench, i snatch it up and rebuild it. now i have quite a collection of "refurbished" wrenches, and some work better than new ones
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | no he don't live in the woods no more, but he sure wishes he did.  | | |
