| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I came across some info in a book I read about an Val-Vin-Hed Silencer. It states that this pad eliminates 50% of valve noise and provides better lubrication. I am not really concearned with the noise but better lubrication is what I would be interested in. The book was Cailfornia Bob's Cheverolet, GMC & Buick Speed Manual, the 1954 edition
The motor I am rebuilding is a 1956 chevy 235 with the 848 heads in a 3100 stepside.
Does anyone have any experience or knowledge about this?
Will this work in my 848 head or is it old technology?
Is this still available and if so where to purchase?
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I have seen these items on eBay and such. TrknGMC installed one on one of his previous trucks. I'm not too sure their claim for better lubrication is true.
This device is basically a canvas diaper that sits on top of the rocker assembly.
If it were my truck, I'd adjust the valves and perform regular maintenance and it will serve you for years.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | That thing is like giving a guy an aspirin for the headache his brain tumor is causing- - - -it's treating the symptom, not the cause of the problem. Valves aren't supposed to be noisy. If they're adjusted correctly, there's no reason to have a silencer pad in place. Lubrication of the rockers gets done by the oil coming through the shaft- - - -by the time it gets to the place it could soak into the pad, it needs to be draining back into the crankcase to get recycled. P.T. Barnum would approve of their marketing strategy- - - -"There's a sucker born every minute!" Jerry
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | Maybe so after seeing the ad posted by tclederman it really look cheesy huh. I am starting to lose confidence it that book.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | The book might have been state of the art in 1954, but that was over 50 years ago when the overhead valve Ford V-8 was the new kid on the block, the Chevy 265 hadn't been marketed yet, and reliable hydraulic lifters in the Chevy 235 and the Buick straight 8 were just a pipe dream. Motor oil capable of working with hydraulic lifters was just getting developed, also.
My father was closely involved with a few GM field engineers in working the bugs out of the Oldsmobile overhead valve V-8, (Introduced in 1949) and one of the problems they dealt with was noisy valve lifters. They used to use his shop in Nashville as an after-hours experimental shop when they were in the southeast. RPM "10-30 Special" oil was one of the first multi-viscosity oils available, and it helped quiet down Olds lifters very well. Kendall also made some special-formula oils to deal with the noisy lifter problem.
Dad was also involved in making the Rochester 4-barrel carburetor work right. Some of the modifications he and the GM guys came up with in 1953 were standard on the Rochester 4GC carburetor in 54. Jerry
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Don't loose faith in the Book Tiny, just rejoice in all those old ads in Popular Mechanics. I had totally forgotten most of them and hadn't seen them since I was a kid. Great stuff.
Maybe another way to look at the valve train diaper is that it functioned as a poor mans oil filter. Silly? Yes. But I'm surprised some clever advertising type didm't claim it. What always astounds me is that this was in the 50's and WWII was won on 40's technology much of which was truly genius. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you check the engines referred-to in the 1954 Speed Manual, I think that all of them were low pressure engines? It's been a while since I looked at that book, and I do not know if that distinction makes a difference.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 28 Chevy car I had came stock with a thick felt pad over the rocker arms. That and an oil can were the only oil for the top end.
Grigg | | |
