1 members (Materman), 115 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#887323 10/06/2012 9:57 AM
Quick question:
We're going to try and rebuild the master cylinder on our 1949 Chevy 3600. Upon removing it the steel brake line corroded itself to the fitting/brake line nut. We had to cut the steel line.
What type of flare are we making to repair the steel brake line? It's been a while smile
Thanks Y'all
Welcome to the site. Where in Washington are you? Be nice to see a pic of your ride too!
Double flare. I have a 1950 3600 that I went through the same thing on. Get yourself a 4 ft 1/4 inch brake line and a cheap bending tool. That worked perfect to go from the master cylinder to the tee fitting along the pass side frame. Here's a pic.
brake line 1
brake line 2
Hope this helps.
PS, if you want to make your own, they are double flared fittings. Get yourself a good flaring tool.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Thank you sir!
We're in Snoqualmie. I haven't had a chance to formally introduce the truck to the forum yet. The little lady saw it in a friends garage and fell in love. So here we are. We'll post up picture when we get it rolling.
Bugger! I have a ISO kit, of course. Maybe We'll just bend a new one.
Wish us luck! And thanks again.
No problem. Just to be clear, you can buy a 4 ft line with the ends already flared and the fittings in place where all you have to do it bend and install. easy@!
Good luck and if you are ever down along the coast, stop by!
David Gilmore
Stovebolt Pictures
Paint progress
1950 Chevy 3600
Success!
The cylinder wasn't heavily pitted and honed up nicely. We went with new line and you're right, that was the way to go. She bled out just after sundown (with a little encouragement).
First Rebuild
[IMG]http://i482.photobucket.com/albums/rr188/JungleJames247/IMG_20121006_190300.jpg[/IMG]
Gasing Up
[IMG]http://i482.photobucket.com/albums/rr188/JungleJames247/IMG_20121006_210009.jpg[/IMG]
Nice
Congratulations
