10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Quick question: We're going to try and rebuild the master cylinder on our 1949 Chevy 3600. Upon removing it the steel brake line corroded itself to the fitting/brake line nut. We had to cut the steel line. What type of flare are we making to repair the steel brake line? It's been a while  Thanks Y'all
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Welcome to the site. Where in Washington are you? Be nice to see a pic of your ride too! Double flare. I have a 1950 3600 that I went through the same thing on. Get yourself a 4 ft 1/4 inch brake line and a cheap bending tool. That worked perfect to go from the master cylinder to the tee fitting along the pass side frame. Here's a pic. brake line 1 brake line 2 Hope this helps. PS, if you want to make your own, they are double flared fittings. Get yourself a good flaring tool.
| | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Thank you sir!
We're in Snoqualmie. I haven't had a chance to formally introduce the truck to the forum yet. The little lady saw it in a friends garage and fell in love. So here we are. We'll post up picture when we get it rolling.
Bugger! I have a ISO kit, of course. Maybe We'll just bend a new one.
Wish us luck! And thanks again. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | No problem. Just to be clear, you can buy a 4 ft line with the ends already flared and the fittings in place where all you have to do it bend and install. easy@!
Good luck and if you are ever down along the coast, stop by! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
