0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | what is the simplest swap to update to more modern powetrain - currently the orignal babbit 235 and 4 -speed what's the biggest displacement / easy swap - Non V-8
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1954-1963 261
Then, GMC 270/302
Then, maybe a 250 or 292 (I know nothing about that "update/upgrade").
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I believe the Chevy 261 CID inline 6 is the easiest. It allows you to use the same tranny and mounting. It is also a full pressure engine and getting harder to locate but they're out there. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Actually, the 54/55st 261 would he the easiest.
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | With a 250 you"ll have to change engine mounts and move radiator forward will work with transmission, some later 250s have cable throttle you'd have to adapt that. | | |
