Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Steelonsteel, TUTS 59), 41 guests, and 8 robots.
Topics128,010
Posts1,055,299
Members48,419
#88672 09/26/2004 2:14 PM
What is the cause of my light flicker on a 12 volt generated systmn?
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
You're using a generator, not an alternator, right? There's a possibility you've got an open leg or two in the armature wiring of the generator. Is the battery staying charged OK? If you can dismantle the generator and check out the armature, look for burned spots on the leading edge of some of the commutator bars, indicating a short in the windings attached to that bar. A "growler" test will confirm any armature problems, open circuits, shorts, or grounds. The trick is finding a shop that still has a growler, and knows how to use it!
Other problems might be dirty points in the voltage regulator, or an incorrect voltage adjustment.
#88674 09/26/2004 11:32 PM
Are your lights grounded to the body or to the frame. If their grounded to the body rather than the frame the gound might not be so good when your moving.
Poor grounds will definitely do that ... or a lose wire -- if your wiring is old, you could have lose connections BIG time.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#88676 09/28/2004 12:13 AM
Well i had the generator rebuilt and tested on a growler a yeAr ago.It charges the battery ok.In fact its charged up good sinse i left the lights on the other day and had to jump it. :p Ill have to check the shed to see if any of my spare regulators are 12 volt or pick one up at a bone yard and try that.I dont think the wires are bad but ill check those too.Thanks guys.Ron
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
Have you checked your switch? I had a loose terminal on my Pontiac light switch that caused my lights to flicker. I soldered it and all's good.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#88678 09/28/2004 10:57 PM
Riding in the Passing Lane
Hook a volt meter up to the bat. & run the engine
around 1200-1500 rpm. You should have about 14volts steady reading. If the voltage is not
steady you should clean the contacts in the
regulator or replace it.
1972 Chevy c10 Cheyenne Super
A lot of possibilities here - the previous posts all make sense.
A few questions...
- Is the flicker rate pretty darn constant, or does it change with rpm, or is it somewhat random?
- Which lights flicker?
- Do the lights flicker only when driving?
- Do you see a flicker with the lights on and the motor NOT running?
#88680 09/30/2004 12:05 AM
A BIG THANKS TO ALL YOU FELLOWS FOR JUMPING IN AND OFFERING HELP!!!!! It turned out to be a very loose ground wire.I didnt know where to begin looking but onse aqain you guys set me on the right path.A very large THANK YOU TO YOU ALL. Ron
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
That's certainly a common failure mode on these old cars. Often the push-in style lamp sockets lose the ground connection from surface oxidation for example. A little twist often gets these working agaion.
Glad to hear you got it fixed!
