2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
what is the simplest swap to update to more modern powetrain - currently the orignal babbit 235 and 4 -speed what's the biggest displacement / easy swap - Non V-8
50 chevy 2-ton dump
71 C-20 Suburban 402/400
72 C-10 Suburban 350/3-speed
Then, GMC 270/302
Then, maybe a 250 or 292 (I know nothing about that "update/upgrade").
I believe the Chevy 261 CID inline 6 is the easiest. It allows you to use the same tranny and mounting. It is also a full pressure engine and getting harder to locate but they're out there.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Actually, the 54/55st 261 would he the easiest.
With a 250 you"ll have to change engine mounts and move radiator forward will work with transmission, some later 250s have cable throttle you'd have to adapt that.
