| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Floor-mats? The only thing that prevents me using OEM mats is my tranny hump is humping no more. With the 700R4 I had to flatten out the cover so the floor is flat from one side to the other. While I would prefer a one piece mat I may have to go to two separate mats. Is there a custom mat vender somewhere?
~Jim
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Any rubber mat will work on a flat floor. Go to Walmart.
Man was created, poof, then poof, woman, no belly buttons. Then in a rage of anger, all were killed except one good boat builder and his family. Then they started the human race all over again. Makes perfect sense.
The human Zygote actually does divide into self-replicating bits called cells. This is true for all organisms except bacteria.
This forum is no place for a signature such as the one you have.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | An Advance-Design 3600?
The standard floor mat should work on a flat floor? The 3-speed floor was flat.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Any rubber mat will work on a flat floor. Go to Walmart.
This forum is no place for a signature such as the one you have. Be careful what you read. We've been over this before.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | An Advance-Design 3600?
The standard floor mat should work on a flat floor? The 3-speed floor was flat. I didn't know that. Thanks Tim.
~Jim
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't know what "be careful what you read" means. Is this a Da Vinci code or something? Anyway, your signature is immature at best, it's not funny nor accurate. I was being absurd to point out an absurd signature. I respectfully ask that you delete it as a signature. You can grind your axe elsewhere. You can discuss creationism, Intelligent Design, evolution and all that on many forums. Everyone else's signature is a funny joke, saying, a quote from someone or a movie quote, not a statement insulting those with a certain point of view about secular/non secular thought.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jim do you need one without the holes already punched in it? At the Kansas City reunion Mike "Ol-Trucks" showed me one that was pretty dang heavy/thick/nice that had the holes in it.....BUT I needed one that didn't have the holes punched so we drove up the street there to Classic Parts and I got one there. Its not quite as thick/heavy but it works nice and if you need a hole the mat is scored nicely on the back side.......just info for you. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks Alvin, I'll check with Classic. Also the Good Guys will be out at Texas Motor Speedway this weekend and a bunch of vendors as well. I pretend to be my wife and spend the day shopping.
~Jim
