10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible),
133
Mod | | | Forums66 Topics128,132 Posts1,056,378 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Do any of you fellows or gals have a good 235 shortshaft waterpump you'd like to sell?
I've got a new 235 waterpump, but so far haven't found a shop here that will pull the hub/pulley from the old one, and squash it on the new pump. This is one of the frustrating things about living in Victoria, no-one wants to work on anything, or won't answer their phone, or won't return phone calls. Grrrrrrrr.
Anyhoo, I'm hoping to find a pump to shove onto my bus right away, instead of waiting for a shortshaft pump from Jim Carter. I'm suddenly loosing a gallon of water a day, which isn't cool (hahaha get it?). It never occured to me that getting the hub/pulley swapped would be a big deal. I figured I had it covered, what with the new pump riding around in the tool box! Dangit!
Thanks.
| | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Hahahaha,
Just after I posted this, I got a call back from a shop that can do it. I'll head down there this afternoon, and drop the pumps off.
| | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | are you talking to yourself,Chris?LOL | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Sometimes, I feel like it!
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey Chris... I wouldn't be posting that you have a short shaft on your water pump! >_< A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I posed this question to Don at JB on Oak and he said he would do it when I needed it done. Press the hub and shorten the shaft. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Ha! That's where I took it, and they couldn't do it. Told me that the shaft size on the new pump was too small, and the old hub could not be pressed on. If they had measured, they would have found that it's just right. So, I'll squash it on with a block of wood and a hammer. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Christopher - use a bottle jack to rig up a press, don't hammer on the shaft!!
Bill | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'll use a clamp, and support the back of the exposed shaft. Or, a jack, the ground, and the frame of the truck! I know I don't want to load up the sides of the bearings. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | This leads me to another question. Where did you get the pump and what year 235 is it supposed to fit? I know I'll need one eventually. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I got the pump from Lordco, in Sidney. I always get Colin to get my stuff. It's a 56-62 235 pump! I don't have the receipt right now for the part number, but it was a reman, and it was only about $45 or so. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I know the pump you mean. Its what I'd need when the time comes. Once you press on the hub will you need to cut the shaft? | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | First, you have to pull off the hub that comes on the pump, then press the old one on, then cut the shaft off. At least, that's the route I need to take on my bus! | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks. Let me know how it works out. | | |
