Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (baldeagle, 3B, Gdads51, Peggy M, Stovebolt48), 48 guests, and 2 robots.
Topics128,004
Posts1,055,250
Members48,418
Do any of you fellows or gals have a good 235 shortshaft waterpump you'd like to sell?
I've got a new 235 waterpump, but so far haven't found a shop here that will pull the hub/pulley from the old one, and squash it on the new pump. This is one of the frustrating things about living in Victoria, no-one wants to work on anything, or won't answer their phone, or won't return phone calls. Grrrrrrrr.
Anyhoo, I'm hoping to find a pump to shove onto my bus right away, instead of waiting for a shortshaft pump from Jim Carter. I'm suddenly loosing a gallon of water a day, which isn't cool (hahaha get it?). It never occured to me that getting the hub/pulley swapped would be a big deal. I figured I had it covered, what with the new pump riding around in the tool box! Dangit!
Thanks.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Hahahaha,
Just after I posted this, I got a call back from a shop that can do it. I'll head down there this afternoon, and drop the pumps off.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
are you talking to yourself,Chris?LOL
Sometimes, I feel like it!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
We are listening.
Big Bolt Forum Co-moderator
Hey Chris... I wouldn't be posting that you have a short shaft on your water pump! >_<
1948 Chevy 2-Ton
Hahaha!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
EEEWW!
I posed this question to Don at JB on Oak and he said he would do it when I needed it done. Press the hub and shorten the shaft.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Ha! That's where I took it, and they couldn't do it. Told me that the shaft size on the new pump was too small, and the old hub could not be pressed on. If they had measured, they would have found that it's just right. So, I'll squash it on with a block of wood and a hammer.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Christopher - use a bottle jack to rig up a press, don't hammer on the shaft!!
I'll use a clamp, and support the back of the exposed shaft. Or, a jack, the ground, and the frame of the truck! I know I don't want to load up the sides of the bearings.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
This leads me to another question. Where did you get the pump and what year 235 is it supposed to fit? I know I'll need one eventually.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I got the pump from Lordco, in Sidney. I always get Colin to get my stuff. It's a 56-62 235 pump! I don't have the receipt right now for the part number, but it was a reman, and it was only about $45 or so.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
I know the pump you mean. Its what I'd need when the time comes. Once you press on the hub will you need to cut the shaft?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
First, you have to pull off the hub that comes on the pump, then press the old one on, then cut the shaft off. At least, that's the route I need to take on my bus!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Thanks.
Let me know how it works out.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Moderated by  Gord&Fran
