3 members (ronsway, dt235sd, 1 invisible), 132 guests, and 2 robots.
Topics128,161
Posts1,056,958
Members48,458
#884 12/06/2003 12:15 AM
i have the original deluxe heater that attaches to the big square hole on passengers inside wall. in order to keep more of the cold air outside and the warm air inside, ive thought about covering up that opening with sheet metal and then puting the heater into place. doing that might keep that exposed side of the heater core covered from that outside, providing more heat to be blown into the cab. am i crazy or has someone else thought about that too? would it even work?
#885 12/06/2003 12:19 AM
Where is the heater going to pull it's air from then? The Fresh Air Heater was designed to pull the air from outside. If you don't want that, cover the vent and replace your heater with the Recirculating Heater.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#886 12/06/2003 12:29 AM
Use a 54 heater housing, it has a door that will allow recirculateing air
#887 12/06/2003 2:19 AM
thanks for that info guys i guess your right, the air would have to go from some where, ill just have to deal with the luke warm air until i can get the recirculating one. thanks too mechainiac, truely an honor to recieve a response from you.
#888 12/06/2003 7:36 AM
Murdock,
I've pulled my recirculating heater from my 52' to repaint it. My neighbor has a fresh air on his 49'. I like his. Want to trade? My core drains(blows through) good. Fan works great. I've repainted it a darker forest green. The fan is just primered and I haven't touched the motor...yet.
Let me know what you think. jeff
If you are interested, look at you firewall from the engine compartment on the passenger side. You should see two (2)5/8" or 3/4" holes vertically alighned about 8" apart. Thats where the hoses run through.
#889 12/06/2003 4:47 PM
It's winter time, why pull your heaters now? Wait until summer or unless you have your truck in non working conditions right now. I have a recirulating heater and it works so well I need to roll the windows down just to cool the cab. Maybe its just all that heat coming through the firewall holes grin
Craig
