1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | I'm putting a 55-62 235 in my 48 chevy half ton , Its been going pretty well up till now I need to change my waterpump for a shorter shaft . I've seen adapter plates for the 216 waterpumps and the short shaft 235 pumps ,Wondering from someone else's experience which is the better choice?? Thanks any help appreciated ! TeeRoy
above all this old truck has taught me patients!
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | I used the water pump adapter when putting a 235 in my 1950 3600. I got mine from predave68 and it worked great. Easy instructions. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I used one from a member here, pre68bowtie, moves the water pump to the center of rad. works great. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | TeeRoy,
Welcome to stovebolt.com.
This topic is discussed quite regularly.
There are variety of ways to search for old posts on different topics. If you push the word Search that is just to the left of FAQ, above, you will see a lot of posts on this topic - type in: +water +pump +plate
The relocation plate, used with the older 216/235 water pump for your earlier year truck, is considered to be the best way to use a newer 235/261 in older trucks. This places the water pump in the correct orientation to the radiator, and at the correct distance from the radiator (and it allows you to use the correct width pulley on the water pump).
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Also if you use the adaptor and use a stock 216 or early 235 water pump,if you break down you can get a water pump from any FLAPS in the area they may have get it the next day but the short shaft pump would have be ordered from a on line store.
I installed the adaptor and it's easy and have never had any problems.
Pete
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | My experiences with the bracket... <thread>
| | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | Thank you Guys, Thats great info. Where is the best place to buy one of the adaptor plates ? I've never done much thread tapping but I think I'll give it a try! TeeRoy
| | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | You can buy it directly from Pre68Dave on eBay. <ebay link> I think The Filling Station also carries them from $5 more. I didn't do any serious tapping either before I did this - but I had a scrap block that I tested my skill on first. Take your time, don't rush, you'll be fine.
| | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | i got mine at napa it was almost a match the heater hose port was the wrong size you can get a new one there too
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I am the odd man out. I ordered a new pump from Patricks and have never looked back. | | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | lilrobo , Are you talking adapter plate or water pump? I went on Ebay and ordered the adapter plate from pre68dave . Can't wait to get it I've been working on this truck for a quite awhile with plenty of set backs and it's getting pretty close to engine start time ! Like I wrote in my signature, This Truck is teaching me patients!!
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Plate went to the PO yesterday!
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | Plate went to the PO yesterday! COOL!!!
