| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 23 | Acquired a 4 spd from a 51 2 ton dump to replace the one in my 52 1/2 ton. 1st question is, are the gears the same? 2nd question. I heard that all I have to do to match it to my torque tube is to change the rear bearing retainer. Is this true? Thanks for any help. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Gears are the same just change the parts on the back of the tranny for your torque tube. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Also change the speedometer drive gear. I think they will just swap, This will keep your speedometer/odometer true.
Kurt | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The drive grear is mounted "on" the transmission output shaft (actually, I dimly recall that it is mounted on the u-joint yoke on an SM420 The driven gear is screwed into the transmission body, and the speedometer cable attaches to it. I think that some drive gears and driven gears can be mixed-and-matched, but they came as matched pairs. I have purchased speedometer adapters from the The Speedometer Shop to get almost perfect mph readouts on two trucks. Also, Bruce Bugay sold me a NOS one set of NOS speedometer gears. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | The big truck transmission will have a parking brake assembly mounted to it. | | | | | Joined: Jul 2009 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 23 | | | |
