2 members (Gray_Ghost, 1 invisible), 179 guests, and 2 robots.
Topics128,109
Posts1,056,269
Members48,439
#884946 09/26/2012 6:01 PM
i have tried this post twice.simple quistion,,are these heads interchangable?what are the advantages or disadvantages...
Yes they are interchangeable but the 292 head might have a bigger combustion chamber, It would lower your compression, not much differant in flow numbers, they both have the same valve size.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Baldy got the long and short of it.
The 194/230/250/292 heads all interchange, including the later integral. They all have the same disadvantage, Siamese intake ports. The 194 combustion chamber smaller and will up your compression, unfortunately it is all so limited performance wise because of valve shrouding. Inliners.org has a partial listing of heads and combustion chamber size. If you need to know what it takes to get performance out of one of the heads check out
http://www.t6racing.org/
Larry
I don't own a vehicle that isn't old enough to drink.
All is correct information. Stay away from the real late model heads with the intake cast into the head. Performance wise, they all will be the same, the late model with the intake cast has a two barrel carb, which might run better, but the heads are prone to heat cracks.
Your best bet is to grab the first good head you find.
For a 250, add 307 Chevrolet V8 pistons for slightly over 1 point compression increase. Its a drop in piston, just be sure its a true flat top, not the universal replacement.
Joe
Joe H #885172 09/27/2012 12:12 PM
i have seen this info about the 307 pistions fitting a 250.i have also read on other forums ,where this will not work.where can i get more info about this???
Look on http://www.inliners.org/. They have lots of info on the 250, including the 307 piston. It's a popular modification. For a 292 you can use LP pistons for higher compression.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
thanks to everone.
For a 230 inline, use a 283 V8 piston, 250s are the same as the 307. It must be a true flat top, some of the universal replacements have lots of valve relief cuts plus a big chamfer around outside edge.
Joe
