4 members (greenie-reddy, pauld, 2 invisible),
85
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | So I am new to this Car restoration. I have done small things prior to this. Coolers, Coffee Grinders and the like. I love to read everything and the internet can be a scary place.
I plan on Priming now and in spring rough up and do the base and clear in a shops paint booth up the road.
My plan was to prime 2 fenders one day. Splash and radiator panels another day hood another, cab another etc - everything is off the truck.
What is this stuff about paint booths exploding? First I am doing smaller jobs. Second I plan on having plastic sheet walls and ceiling in the garage - no lights inside. a couple fans blowing air into the platic room (cut outs/duct tape in the plastic - fans outside) the outlet has no fan just a filter into a large window.
I feel this will minimize the risk of me being vaporized with the small amount of painting I will be doing.
Am I crazy? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I'd worry more about the air your breathing while your spraying than annihilation in a fiery explosion. And just how many paint booths are exploding any way? Anyone have some stats to share?
| | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I have never heard of an exploding booth. I agree with more concern given to the air you are breathing. The fumes are not good for you. | | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | Thanks I have a good charcoal filtered (NEW FILTERS) respirator that I use. I even have one fitted for the dog.
Can't wait to see what this piccaso can do. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | The reason you don't hear about exploding paint booths is because of the regulations paint booths have to abide by. Every wonder why the lights are outside the booth? Most folks haven't actually seen the electric motors but they are shielded (or separated from the air stream) so no sparks are around the explosive vapor. Just because you don't hear about them exploding doesn't mean they wont explode.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I've never heard of an exploding paint booth. Can you expand on what you heard? | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | He's doing painting in an at home garage paint booth. Plenty of reasons for an accidental explosion in a makeshift booth if precautions aren't taken.
Drew
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | SO I got done doing two fenders, two running boards Radiator splash guard and all went well. The fumes from cleaning seem stronger than the painting.
I guess it is normal that you can see the filler outlined under the epoxy primer. Or maybe I did not put enough paint on.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you can see it because the filler absorbs the primer more - it's sealed now so subsequent coats of anything act more like the non-filled areas
Bill | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Can't see a problem with what you are doing, just make sure your mask is rated for what you are spraying. Furnace, hot water heater - pilot lights all off and a single fan pulling are into the area. Most of the EXPLOSIONS I have heard about come about when a person is cleaning a spraybooth. A shop down the street ran into a problem when the bonehead took a shopvac in to clean the overspray that had built up on the floor, another thought it would be a good idea to mix the 5 gallon bucket of finish with an electric drill.....BAM! Sparks and open flames are a NO NO.
....David
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Also, the chemicals in the paints can be absorbed through your skin also. Take precautions to cover your skin (and ears) when painting. | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | Sparks and open flames are a NO NO. That's why it's not a good idea to use any electric device with explosive vapors around. Electric motors' brushes cause sparking. That's why in professional booths the electric devices are separated from the vapor stream.
