0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#884507 09/24/2012 9:38 PM
.... Does anyone on the site have a 261? and if so ....do you know the color code (or shade of Green) for that engine?
Regards
Cliff(hunting the engine color)59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
Detroit Diesel Alpine green, I buy mine in spray cans from NAPA by the case
http://rides.webshots.com/photo/2799861370080251109JhTguU
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Ditto what Grigg said...
Krylon Detroit Diesel, Alpine Green:
UPC #2691691618, Stock #DE1618
I had to have my NAPA store order the cans for me but it wasn't a big deal.
When you use a spray-can paint, do you use a primer?
Do you do any special metal-prep?
I used a primer after thoroughly cleaning the parts and light sanded before priming and after to insure a good adhesion all the way around.
I'm not a painter by any means but it seemed to be practical for the results I wanted, so I did it... labor overkill?
I'm happy with the results.
I do, the instructions on the engine paint from NAPA say to use primer part number DE1612.
Just the usual prep of removing all grease, oil, dirt, and paint if possible. I've painted several Detroit diesel engines this way and they turn out really nice.
Grigg
---All pictures---
Thanks, Grigg
That is what I have been using. I am about ready to paint a 1954 235 (gray) and a 1954 270 (orange-red).
Tim -
I cleaned on my 235 for a few days to try to remove all grease and oil. Let it dry it thoughly, then painted it before oil started seeping out of any leaky gaskets.
I removed the valve cover and push rod cover. Primed them with self-etching primer, sprayed sandable primer, and then wet sanded. Looks good, especially if there are rust pits on them. I used Duplicolor engine primer on the covers and on the entire engine before shooting with Filling Station gray. Primers and engine paint were all in rattle-cans. I also bought a pint of brushable engine paint for the hard to reach areas. An HVLP gun on an engine that is on an engine stand would be much better than rattle cans.
Are you painting the engines while they are in the trucks or out? I painted mine without removing from the truck. I didn't have a good plan - if that is even possible. I spent 90% of my time masking, 10% painting, then back to 90/10 mask/paint to repaint overspray items. Then again and again and again.
> Masked
> Finished
- Lonnie
My '54 3104
Canadians looking at this thread may say to themselves "that green is nothing like what is on my donor Pontiac 261". GM Canada used many different shades of green which can be seen here:
http://canadianponcho.activeboard.c...ad-261-big-six-strato-six-engine-colour/
You Tube
