Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (WICruiser, Guitplayer, Southerntruck), 46 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#884105 09/22/2012 11:51 AM
hey guys, just bought a 1979"Camper Special" that has a running 350 in it for a project. It needs a rebuild and was wondering if anyone knew where to find the correct #'s off the block to see which motor i'm dealing with b/f i dissasemble it. it may or may not be the original. it's a duelly so i assume it's a one ton, correct me if i'm wrong.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
darenhg72 #884129 09/22/2012 3:18 PM
they are either on the head(s) or on the intake manifold,i got a 79 gmc sierra classic that has the original motor and the numbers are hidden under 33 years of grease and grime there, so get a wire brush, wd-40 and some rags and see if you can find em, that should give you a place to start. let me know how it goes.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Materman #884142 09/22/2012 5:15 PM
Small blocks are stamped on the front surface pad,on the block. pass.side,by the water pump bolt hole.Should be all the numbers you need to see.It should be a flat spot.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
darenhg72 #884183 09/22/2012 11:20 PM
There is a machined pad just ahead of the passenger's side cylinder head. The 2 or 3 letter suffix at the end of the stamping will identify the original application. Virtually all the truck engines with 4-bolt main bearing caps have a "T" as the first letter of the suffix.
Hotrod Lincoln #884250 09/23/2012 1:20 PM
going out to look see. thanks
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
darenhg72 #884256 09/23/2012 3:31 PM
ok - unfortunatly i found out that according to the #'s i have a 305 v8. good enough for this project, but unexpected in this truck. it's out of a '83 parisien? i think it said. for what i paid for the truck, no harm. runs to good not to use though.
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
darenhg72 #884265 09/23/2012 5:07 PM
You'll need more than the 2 digit suffix code. You will find the block is stamped with a casting number and date behind the driver side cylinder head. Combine that info with the suffix code (2 letters in front of the passenger side cylinder head).
